Constantin Wiesener
Apr 24, 2017 3:10 PM UTC
Flash a cascade of STM32 with bootloader
Posted on April 24, 2017 at 17:10
Consider the following setting:
One MAIN STM32F407 and one LOW STM32F407.
There are both connected via a UART. But only the main is connected with the UART to a flasher.
How could I flash both CPU (both are running with bootloader) through the one UART connected to the MAIN CPU?
Thanks for your help and best regards,
Constantin
    Apr 24, 2017 3:48 PM UTC
    Posted on April 24, 2017 at 17:48
    Make a simple forwarder that copies the data too/from the main device to the slave, so as to create a tunnel. ie data received on one USART is transmitted out the other. Pick a common speed, ie 9600 8E1
    You could also have the main device use the loader protocol to flash the slave.
    Constantin Wiesener
    Apr 25, 2017 8:23 AM UTC
    Posted on April 25, 2017 at 08:23
    okay, are there any examples on how to start?
