Gpeti
Senior
June 3, 2019
Fixed version of Cortex in STM32H7 ?
I've heard that some bugs have been found on Cortex M7 related to cache management, and that the STM32H7 will embed the fixed version of Cortex design. But I can't find when this updated version of STM32H7 will be available. Also, where (in what document) is the ARM Cortex M7 design revision specified ?
Max
The correct place to look for this type of information is the product errata-sheet.
but it won't show you future/planned silicon revision until they become available.
if you need more information about products or revisions that are not yet available, you must to ask your local ST contact.
June 3, 2019
H7xx r1p1
CPUID 411FC271 DEVID 450 REVID 1001 Cortex M7 r1p1
CPUID 411FC271 DEVID 450 REVID 1003 Cortex M7 r1p1 STM32H7xx Rev Y
I don't have my Rev V to hand, but I think that's the same r1p1 core. Will check later
Try the Reference Manual or the Errata
Gpeti
GpetiAuthor
Senior
June 3, 2019
Hello, the errata sheet mentions that the bugs of version r0p1 are present on all versions of STM32H753, so I'm surprised that you mention r1p1 ?
June 3, 2019
I've tracked this stuff pretty comprehensively, definitely reporting r1p1
https://static.docs.arm.com/ddi0489/d/DDI0489D_cortex_m7_trm.pdf
https://community.st.com/s/question/0D50X0000AnssYLSQY/how-can-i-check-the-revision-of-the-m7-core-without-checking-the-registers
ST's only used r0p1 in the first generation CM7 parts the F746/F756/F750
Gpeti
GpetiAuthor
Senior
June 4, 2019
​Thank you Clive, it's quite helpful as I don't have a Nucleo up and running yet. So the errata sheet is wrong for this product (at least for the core version).
Piranha
Principal III
June 4, 2019
STM32H7: AN4891 section 2.6.
STM32F7: AN4667 section 1.7.
Real bugs with cache management are in ST's software. Their code monkeys are not able to understand cache management, multi-threading, full-duplex communication, asynchronous events, memory barriers and even optimal use of local/volatile variables.
Gpeti
GpetiAuthor
Senior
June 4, 2019
​AN4891 is not a document but a software expansion X-CUBE-PERF-H7. Typo ?
ARM describes some real hardware bugs related to cache, including on the r1p1, and this is what my company is concerned about. I don't see the link with potential software bugs from ST.
