hajermarnissi
FILE AXF
Posted on March 21, 2011 at 13:34
FILE AXF
    May 17, 2011
    Posted on May 17, 2011 at 14:29
    I did not
    understand
    my
    messages
    give
    a
    very
    different
    impression
    Don't feed him! He is observing that you *don't* have a mastery of the topics at hand, or nuances of the English language.
    Andrew Neil
    For using Keil, start with the MDK-ARM Primer
    http://www.keil.com/support/man/docs/gsac/
    The uVision User Guide is here:
    http://www.keil.com/support/man/docs/armcc/
    It includes a couple of worked examples:
    http://www.keil.com/support/man/docs/uv4/uv4_examples.htm
    The RealView Linker User Guide is here:
    http://www.keil.com/support/man/docs/armlink/
    In particular, take a look at this section - getting information about the generated image:
    http://www.keil.com/support/man/docs/armlink/armlink_chdcjdgb.htm
    There is also a RealView Linker Reference Guide:
    http://www.keil.com/support/man/docs/armlinkref/
    Keil provide a number of STM32 examples here:
    http://www.keil.com/download/list/arm.htm
    Speak to your local Distributor about local training & support in your own language.
    If this is a commercial project, you could try contacting one of the design consultants listed here:
    http://www.st.com/internet/com/support/mcu_design_consultants.jsp
    (again, your local Distributor may know of others).
