SAIDHI REDDY SAREDDY
FFT problem on stm32427- solved
Posted on April 20, 2017 at 16:11
I have done fft computation but I got strange results.Please let me know if i did any mistake.
why I am getting the following strange results?
// ADC
&sharpdefine ADC_RAW_LENGTH 512
// FFT
//&sharpdefine FFT_SAMPLES 2048
&sharpdefine FFT_SIZE ADC_RAW_LENGTH/2
UINT16 ui16ADCRaw[ADC_RAW_LENGTH],ui16ADCCnt = 0,ui16Flag = 0, ui16CalibrateMaxValue = 0;
FLOAT32 fl32ADCRaw[ADC_RAW_LENGTH], fl32FFTOut[FFT_SIZE], fl32FFTMaxValue = 0;
UINT32 ui32FFTMaxIndex = 0;
arm_cfft_radix4_instance_f32 FFT_InitStruc;
arm_cfft_instance_f32 FFT_InitStruc_dsp;
arm_status status = ARM_MATH_ARGUMENT_ERROR; // default failure
//input data collection with timer interrupt from adc
void TIM2_IRQHandler(void)
UINT16 ui16ADC_Value = 0 ;
TIM_ClearITPendingBit(TIM2, TIM_IT_Update);
ui16ADC_Value = ADC_GetConversionValue(ADC1) ;
if((ui16ADCCnt < ADC_RAW_LENGTH) && (ui16ADC_Value > 500) )
if((ui16CalibrateMaxValue < ui16ADC_Value) ) {
ui16CalibrateMaxValue = ui16ADC_Value;
fl32ADCRaw[ui16ADCCnt] = (FLOAT32)ui16ADC_Value;
ui16ADCCnt++;
fl32ADCRaw[ui16ADCCnt] = 0.0;
ui16ADCCnt++;
// FFT calculation
status = arm_cfft_radix4_init_f32(&FFT_InitStruc,FFT_SIZE,0,1);
arm_cfft_radix4_f32(&FFT_InitStruc, fl32ADCRaw);
arm_cmplx_mag_f32(fl32ADCRaw,fl32FFTOut,FFT_SIZE);
arm_max_f32(fl32FFTOut, FFT_SIZE, &fl32FFTMaxValue, &ui32FFTMaxIndex);
// input sample data fl32ADCRaw
503
0
507
0
516
0
514
0
524
0
530
0
532
0
537
0
//arm_cfft_radix4_f32 function fl32ADCRaw
388595
0
0
0
-1186
1163
-1087
0
4.66130239e+011
-4.66130239e+011
-1186
-1163
4.66130239e+011
4.66130239e+011
-4.66130239e+011
4.66130239e+011
0
0
-4.66130239e+011
-4.66130239e+011
0
0
0
0
nan (0x7fffff)
nan (0x7fffff)
0
0
nan (0x7fffff)
nan (0x7fffff)
nan (0x7fffff)
nan (0x7fffff)
2.48002616e+012
//arm_cmplx_mag_f32 function fl32FFTOut data
5.66332883e+011
5.68833212e+011
1.86279645e+018
7.30765853e+011
1.86279645e+018
1.86279645e+018
0
1.86279645e+018
0
0
0
0
0
0
0
1.16413673e+013
0
1.67605685e+012
6.25887412e+011
inf
1.60195215e+012
inf
inf
0
inf
0
0
0
0
0
0
inf
0
inf
inf
inf
inf
inf
inf
0
inf
0
#stm32f427 #fft-stm32f4 #fft
Amel NASRI
Posted on April 20, 2017 at 17:39
Hello
SAREDDY.SAIDHIREDDY
You marked your question as '
ASSUMED ANSWERED
Does this mean that you have no more problem with FFT?
What did you made to resolve it?
It is interesting to share your findings with other Community members.
-Amel
April 20, 2017
Posted on April 20, 2017 at 18:01
Are you sure it is not the forum software? I think it does this if other questions contain similarmaterial, and get answers, etc.
https://community.st.com/0D50X00009XkXxlSAF
Posted on April 21, 2017 at 13:23
I did small mistake ..
I did not add arm_common_tables.c file. FFT  is working with below required files.
