FatFS on STM32CubeMx question ?
Posted on January 22, 2016 at 15:29
Guys,
I tried to use HAL_SPI from STM32CubeMX with FATFs but I got this error when I compiled the function below argument of type ''const BYTE *'' is incompatible with parameter of type ''BYTE *'' How can I fix it ?DRESULT disk_write(BYTE pdrv,
const
BYTE *buff, DWORD sector, UINT count)
DRESULT res;
if (pdrv || !count) return RES_PARERR;
if (Stat & STA_NOINIT) return RES_NOTRDY;
if (Stat & STA_PROTECT) return RES_WRPRT;
if (!(CardType & CT_BLOCK)) sector *= 512; /* Convert to byte address if needed */
if (count == 1) { /* Single block write */
if ((send_cmd(CMD24, sector) == 0) /* WRITE_BLOCK */
&& xmit_datablock(buff, 0xFE))
count = 0;
else { /* Multiple block write */
if (CardType & CT_SDC) send_cmd(ACMD23, count);
if (send_cmd(CMD25, sector) == 0) { /* WRITE_MULTIPLE_BLOCK */
do {
if (!xmit_datablock(buff, 0xFC)) break;
buff += 512;
} while (--count);
if (!xmit_datablock(0, 0xFD)) /* STOP_TRAN token */
count = 1;
deselect();
return count ? RES_ERROR : RES_OK;
//res = disk.drv[pdrv]->disk_write(buff, sector, count);
//return res;
thanks
