vinicius_acvasconcelos
Jan 29, 2009 3:14 PM UTC
FAT system and SD Card, ARM STM32F103RBT
Posted on January 29, 2009 at 16:14
    May 17, 2011 10:58 AM UTC
    Posted on May 17, 2011 at 12:58
    I`m using ARM STM32F103RBT6. I`m able to record and read data in SD Card with a raw format(Using simple SPI).
    But I have to use the FAT system because after recorded the card will be read on a PC.
    Anyone have any library, documentation or example using FAT to help me?
    Thanks,
    Vinícius
    mdeneen
    Check this thread:
    http://www.st.com/mcu/forums-cat-6318-23.html&start=10
    It works quite well!
    Quote:
    On 13-01-2009 at 09:22, Anonymous wrote:
    I've post working example hire:
    http://www.st.com/mcu/forums-cat-7702-23.html&start=10
    Thanks for the example:-D. I tried your exemple, but the CrossStudio give a message:
    'printf.c:(.text+0x30): undefined reference to `__putchar'
    Its the only problem, all the rest seems to work pretty well.
    Could you have any idea how can I solve this problem?
    Quote:
    On 12-01-2009 at 20:40, Anonymous wrote:
    Check this thread:
    I tried your Code :-[ . First I had to change all ''SPI_FLAG_TXE'' to ''SPI_I2S_FLAG_TXE''
    After that I was able to compile the code.
    But Didn't Work, I start the debug and the CrossStudio tell: Error reading Memory.
    Someone has any idea to make this code works?Has it?
    [ This message was edited by: vinicius_acvasconcelos on 14-01-2009 19:32 ]
    [ This message was edited by: vinicius_acvasconcelos on 14-01-2009 19:34 ]
    jaroslaw2
    Quote:
    On 15-01-2009 at 23:21, Anonymous wrote:
    Read this:
    http://www.rowley.co.uk/documentation/arm_1_7/hcc_customizing_putchar.htm
    [ This message was edited by: slawcus on 15-01-2009 23:21 ]
    Thanks!:-D Its solve the putchar problem, now I'm can compile the code. Today I will test with the Sd Card, and will see if the code realy works.
    slawcus
    Read this:
    gabrielbonato
    I'm problem, not function fat file system examples.
    Please help!
    I Fixed the __Putchar problem, but your code give a HardwareFault Excepition. What I have to do to this write the data on SD Card in Fat System??? :o
    gabrielbonato
    I'm using msd library st (UM435 - STM3210B-EVAL demonstration software), to adapt for spi2.
    it does not function.
    I'm problem .
    function MSD_ReadByte() not response.
    /* Check if response is got or a timeout is happen */
    while ((MSD_ReadByte() != Response) && Count)
    Count--;
    if (Count == 0) /// count = 0 not response
    /* After time out */
    return MSD_RESPONSE_FAILURE; //always
    else
    /* Right response got */
    return MSD_RESPONSE_NO_ERROR;
