mwp
F401 Enabling ROP?
  • May 14, 2018
  • 3 replies
  • 784 views
Posted on May 14, 2018 at 20:27
Hi all,
I'm trying to get ROP enabled by my bootloader.
This function is run first up by main().
I'm finding that it get stuck in a loop, as ROP never seems to become enabled (always reads back as being set at level 0).
Any ideas what im doing wrong here?
Thanks.
void BL_ROPL1()
FLASH_OBProgramInitTypeDef OBInit;
//check ROP status
HAL_FLASHEx_OBGetConfig(&OBInit);
if (OBInit.RDPLevel == OB_RDP_LEVEL_0)
  //no read out protection is active, enable it
  OBInit.OptionType = OPTIONBYTE_RDP;
  OBInit.RDPLevel = OB_RDP_LEVEL_1;
  HAL_FLASH_Unlock();
  HAL_FLASH_OB_Unlock();
  HAL_FLASHEx_OBProgram(&OBInit);
  HAL_FLASH_OB_Lock();
  HAL_FLASH_OB_Launch();
  NVIC_SystemReset(); //shouldnt get to here
#rop #security #stm32 #stm32f401 #protection
May 14, 2018
Posted on May 14, 2018 at 20:39
You should perhaps unlock the Flash/OB first, and pay attention to status returned.
mwp
mwpAuthor
Posted on May 15, 2018 at 19:27
Okay, here is the full thing.
All i ever see is a flickering green LED (flickering due to the boot loop).
Never a red LED indicating an issue.
void
BL_Flash_Protect()
#ifndef BL_DONT_PROTECT
//get ROP status
if
(HAL_FLASH_Unlock() != HAL_OK)
goto
ferror;
if
(HAL_FLASH_OB_Unlock() != HAL_OK)
goto
ferror;
if
//disable flash read out to external devices
        LL_GPIO_SetOutputPin(LED3_GRN_PIN);
if
(HAL_FLASHEx_OBProgram(&OBInit) != HAL_OK)
goto
ferror;
        HAL_FLASH_Lock();
//restarts
        NVIC_SystemReset();
    HAL_FLASH_Lock();
return
    ferror:
while
(1)
        LL_GPIO_SetOutputPin(LED3_RED_PIN);
        __BKPT(0);
#endif
mwp
mwpAuthor
Posted on May 15, 2018 at 21:06
Solved!
I misunderstood the function of HAL_FLASH_OB_Launch().
The correct working order is:
HAL_FLASH_Unlock();
HAL_FLASH_Lock();
NVIC_SystemReset();
