f373 SDADC one input is pulling down.
Hello, I have a custom designed board with 7 analog inputs on sigma delta ADC's.
6 of my inputs are working properly.
I have a software issue.
When I erase the flash or de-solder the mcu I can measure the correct voltage from my test points.
But when I upload the stmcubeide generated empty project, only 1 input goes low. Other 6 inputs are ok.
Where to check? What to check?
