JLee.37
F303 OP AMP related inquiry
  • April 20, 2021
  • 1 reply
  • 795 views
I want to control the OP AMP using F303. I opened all OP AMPs and received ADC values ​​in the form of Follower, but OP AMP4 does not work. What's the problem?
Amel NASRI
Hi @JLee.37​ ,
  • Does OPAMP4 work as standalone (when other OPAMPs are not used)?
  • Based on RM0316, used pin for OPAMP output to ADC input is PB12. Is it configured properly?
-Amel
