Jun 4, 2024 10:25 AM UTC
external RAM for stm32h753zi
Hi, my program required a large amount of RAM memory, how can i know which external memory i can choose? and which peripheral is dedicated for this?
Peter BENSCH
Peter BENSCHBest answer
Jun 4, 2024 11:57 AM UTC
External RAM can be connected either in parallel (SRAM, PSRAM) via the peripheral FMC or serially via SPI(QSPI). Details can be found in the data sheet of the STM32H753 and in the reference manual RM0433.
Hope that helps?
/Peter
Peter BENSCH
Hope that helps?
/Peter
DitzhakAuthor
Jun 4, 2024 12:24 PM UTC
Thank you for the quick answer it was very helpful.
DitzhakAuthor
Jun 4, 2024 12:31 PM UTC
@Peter BENSCH  Can you direct me to an external memory that matches my MCU?
Peter BENSCH
Jun 4, 2024 1:30 PM UTC
There are loads of external types of RAM from various manufacturers that will fit on your board, so it's almost impossible for me to make a list of them.
It would make sense to check whether you can get by with the internal RAM, e.g. by optimising the program, eliminating unnecessary arrays and recurring variables, or even switching on the compiler's memory optimisation. If there is still not enough RAM, you should then think about which and how much data you want to swap out, and how quickly you want to access it. You can then find out whether and which type of RAM is suitable and what you need to look for from the manufacturers in question.
Good luck!
/Peter
