External power supply STM32L432KC
I was experimenting with the L432KC board. While connected to the computer everything worked fine, but as soon as I tried to use an external power supply everything stopped working. More specifically the board's led LD1 slowly flashes when connected to the external power supply. I firstly tried a USB powerbank when I encountered this problem, then i read a thread saying that due to an USB enumeration problem, this couldn't be a viable solution.
I also tried using a battery pack connected to every combination of inputs possible (accordingly to Table 5 in the user manual).
I also tried to close the SB10 bridge, but the result is always the same.
