NCatt.1
Expand struct in flash without change location of next data
Hello everyone,
I currently have devices with a specific FW released on market. In this FW there is a structure saved in internal flash memory (with "const" and defined areas on linker file).
In the new version I am working on, I need to expand an array placed in the middle of this structure. The problem is that data next to this array will change location by doing this, what I would like to avoid.
Is there a way to add the new data of the array at the end of the structure ? Or any other idea ?
Thanks a lot for your help !
Andrew Neil
Andrew NeilBest answer
"Is there a way to add the new data of the array at the end of the structure ?"
You'd have to add another, separate array - and your code would have to cope with concatenating the two parts:
struct
 original_array[ORIGINAL_SIZE];
 next_item;
 extra_array[EXTRA_SIZE];
"any other idea ?"
If you have plenty of Flash space to spare, Code which handles the new, bigger array just ignores the original_array, and takes everything from the extra_array.
struct
  original_array[ORIGINAL_SIZE]; // No longer used
  next_item;
  extra_array[ORIGINAL_SIZE+ EXTRA_SIZE]; // Everything is now here
Andrew Neil
struct
 next_item;
"any other idea ?"
struct
  next_item;
NCatt.1
NCatt.1Author
This is what I thought I would have to do. This involves many changes in my code for managing it but no choice.
Thanks anyway for your answer !
Andrew Neil
@NCatt.1​ ​  "This involves many changes in my code"
Then this may be a good opportunity to re-factor your code so that's no longer the case?
eg, make "getters" for retrieving stuff from your struct - then the only change would be in the "getter" ...
If your question is now resolved, please mark the solution:
Andrew Neil
hang on a minute:
@NCatt.1​  "The problem is that data next to this array will change location by doing this, what I would like to avoid."
Why is that a problem that you want to avoid?
Surely, the whole point of a struct is that you access its members by name - so it shouldn't matter where they appear within the struct?
NCatt.1
NCatt.1Author
Because I store device configuration in this structure, and at restart I use it to reset or not the device.
If there is a new variable between 2 restarts, variables after this new will be shifted in memory and data will be lost
waclawek.jan
I don't understand, can you please elaborate more on this? Perhaps giving a simplified example? Or illustrate it with some drawing?
Are you talking about migration between old and new version of the firmware?
Andrew Neil
@Community member​ "I don't understand"
Neither do I.
For the struct to change in Flash, the code running on the STM32 would have to update it - so that update should ensure that data is not lost?
