Tteva.1
Dec 8, 2020 9:56 AM UTC
Example of SDMMC on STM32H757 i-EVAL Board
Hi everyone .
I'm looking for a demo code to run the SD card (16gb) with FatFs on the STM32H757 i-EVAL Board.
When I generate it with CubeMx the demonstration doesn't work (I didn't forget to activate the transiver)
Thanks you =)
Tteva.1
Tteva.1Best answer
Dec 8, 2020 12:16 PM UTC
Ons KOOLI
Dec 8, 2020 10:31 AM UTC
Hi Tteva.1,
Can you please share your .ioc file ?
Else, you can refer to the STM32CubeH7 Firmware. You can find examples and applications that can help you.
Best Regards,
Ons.
Tteva.1
Tteva.1Author
Dec 8, 2020 1:28 PM UTC
Hi Ons KOOLI ,
Thanks you for the reply. Yes i can share :)
If you see an error ;)
Tteva.1
Tteva.1AuthorBest answer
aasil
Sep 25, 2021 7:33 PM UTC
Hi Tteva.1,
I want generate code with CubeMx for sdmmc1 on STM32H757i- EVAL but it doesn't work ... i used stm32h747.c lib and i also tried to change example of stm32h743- eval (sd_read_write_HS_dma) but it doesn't work...
I'm really confused about ...
do you find any solution for it??
Best Regards,
amir.
