jeffj2
EWARM5.41 output BIN generate DFU file not work
  • May 6, 2010
  • 1 reply
  • 1426 views
Posted on May 06, 2010 at 04:58
    chikos332
    May 17, 2011
    Posted on May 17, 2011 at 13:50
    Hi Jeff,
    I had the same issue as you. I just used Hex format instead of binary and it worked correctly.
    Seems to be issue in EWARM ....
