Ethernet : LwIP stm32h735 Memory
I'm trying to implement an STM32H735 device with LwIP and FreeRTOS. I've been following this documentation: https://community.st.com/t5/stm32-mcus/how-to-create-project-for-stm32h7-with-ethernet-and-lwip-stack/ta-p/49308
Although I've managed to resolve debugging errors, I'm still unable to successfully ping the device. Any assistance from fellow developers would be greatly appreciated.
HispaEmoBest answer
Okay, I've managed to successfully ping. My goal is to build layer by layer until implementing Azure IoT.
By the way, I followed this video: https://www.youtube.com/watch?v=8r8w6mgSn1A&list=PLfIJKC1ud8ggZKVtytWAlOS63vifF5iJC
I ignored PoolSection.
I'll post again if I encounter more issues.
Best wishes.
jumman_JHINGA
Senior III
January 16, 2024
Hii @HispaEmo  Compare Ethernet GPIOs pins configured in CubeMx with GPIOs Pins mentioned in your Device Data sheet. if pin is configured wrongly then correct it. otherwise mentioned your what exact issue your facing.
HispaEmoAuthor
Hello @jumman_JHINGA
Thank you very much for responding. I've been trying this for a few days, and your guidance is really helpful. I'll be more specific so that we can resolve it as soon as possible.
Starting with the pins:
As you mentioned, the first thing I checked was the pins, as the CubeMX tends to assign them incorrectly.
Here comes my first question: with STM32H735, is Ethernet configuration possible with MII? Because in the board's schematic, I only see pins associated with RMII.
Regarding Rx_PoolSection, I've read that it's not necessary to define it, although I've tried modifying the ethernetif.c file.
I usually set:
Tx 0x30000100
Rx 0x30000000
Rx_PoolSection 0x30000400
The configuration of the Cortex M7 and its memory regions is one of the things that generates the most doubt for me. What size should I use, and what are the MPU options?
I would like to know the most relevant options that may have changed in https://community.st.com/t5/stm32-mcus/how-to-create-project-for-stm32h7-with-ethernet-and-lwip-stack/ta-p/49308.
I'm reading your response carefully, and thank you very much.
Senior
January 29, 2024
Does it mean STM32IDE also could assign them incorrectly?
HispaEmoAuthor
yes ETH pins pb10 pb11 pb12...
HispaEmoAuthorBest answer
Best wishes.
