Posted on May 08, 2018 at 17:22 Hello
nada.ali.1685
You may find theprovided Ethernet examples by mbedrelated to your board on this page
https://os.mbed.com/platforms/ST-Nucleo-F429ZI/
https://os.mbed.com/teams/ST/code/mbed-os-tcp-server-example/?platform=ST-Nucleo-F429ZI
In fact, you have many choices to develop on STM32 depends on your needs and what should use :
As example, you can refer to the LwIP example with
http://www.st.com/content/st_com/en/products/embedded-software/mcus-embedded-software/stm32-embedded-software/stm32cube-mcu-packages/stm32cubef4.html
fimware package that you can download from ST website: STM32Cube_FW_F4_V1.0\Projects\STM32F429ZI-Nucleo\Applications\LwIP
This ready-to-use applciation can help you as an implementation example and get inspiration to achieve you goal.
You can also use STM32CubeMxtool to initialize peripherals, build and generate your starting Ethernet project with initialization C code.
I suggest that you take a look to the following ressources:
http://www.st.com/content/ccc/resource/technical/document/application_note/fd/5d/64/cf/7c/38/4c/30/DM00036pdf/files/DM00036pdf/jcr:content/translations/en.DM00036pdf
Application note“LwIP TCP/IP stack demonstration for STM32F4x7 microcontrollers�?
http://www.st.com/content/ccc/resource/technical/document/user_manual/65/e8/20/db/16/36/45/f7/DM001036pdf/files/DM001036pdf/jcr:content/translations/en.DM001036pdf
: “Developing applications on STM32Cube with LwIP TCP/IP stack�?
Hope this helps you.
Best Regards,
Imen
