ETH_REF_CLK (PA1) noise / crosstalk on ADC1_IN0 (PA0)?
Has anyone seen ADC noise generated by the 50 MHz RMII clock (PA1) affecting the measurement on ADC1_IN0 (PA0)? (approximately 100 codes in 4096).
If so does anyone had a fix to suppress it?
All other ADC channels used do not have the same level of noise (approximately 10 codes in 4096), and when ETH_REF_CLK is removed, the noise is the same as the other ADC channels.
Part STM32F437 LQFP100.
TIA.
