gigo
Error while erasing flash ROM
Posted on February 18, 2016 at 06:56
I am using STM32F427IG microcontroller. The Flash Rom is connected to the FMC Controller.  I am getting error when I tried to erase a sector of flash memory. The error status flags- PGSERR, PGPERR was set. It worked fine when I cleared this error flags and tried again.
This error exists when I tried to erase again. So everytime, I need to clear the status flag and have to try again.
    waclawek.jan
    Posted on February 18, 2016 at 09:00
    So, you have an external FLASH connected to the mcu? What kind of it?
    These flags are related to *internal* memory, not to external memory connected through FMC.
    gigo
    gigoAuthor
    Posted on February 18, 2016 at 09:31
    Sorry, I was wrong.  We are using the internal flash.
    pkumar1883
    Posted on February 18, 2016 at 11:05
    Could you unlock the flash successfully. Not sure about your part number but I think that you cant erase a sector, you only can erase complete page.
    So the better way to erase a sector is first read the complete page content. keep that in RAM(buffer). Edit the desired sector location in RAM. Erase the page and write the updated RAM(buffer).
    /*Please
     mark helpfull
     if this post helps you or solves your problem.*/
    /* If you need any personal support for your work please contact at
    embeddeddesign.help@gmail.com*/
    February 18, 2016
    Posted on February 18, 2016 at 19:40
    You're doing something wrong, what exactly that is is hard to know from your presentation of the problem. Refine your presentation.
    Show you code, ideally a sufficiently complete example, that demonstrates the failure.
    The erase on the F4 takes a block number, not an address.
