parisa
Error in receiving serial data(USART)
Posted on October 24, 2016 at 20:50
Hello
Here is my code:
void
USART1_IRQHandler(
void
if
(USART_GetITStatus(USART1, USART_IT_TXE) != RESET)
if
(DataReady==1 && count<=150){
if
(msg[count]==
'\0'
){USART_ITConfig(USART1, USART_IT_TXE, DISABLE);DataReady=0;}
USART_SendData(USART1,msg[count]);
count=count+1;
if
(DataReady==0 || count>=150){USART_ITConfig(USART1, USART_IT_TXE, DISABLE);DataReady=0;}
if
(USART_GetITStatus(USART1, USART_IT_RXNE) != RESET)
temp=USART_ReceiveData(USART1);
if
(temp==65){
Received=1;
bitpos1=0;
else
if
(temp!=66 && Received==1 && temp>47 && temp<58){
bufferu1[bitpos1]=temp;
bitpos1+=1;
else
if
(temp==66 && Received==1)
Received=0;
cop1();
endbitpos1=bitpos1;
SerialFlag=1;
else
if
(Received==1 && bitpos1>150){
bitpos1=0;
Received=0;
else
if
(bitpos1>150){
bitpos1=0;
Received=0;
Unfortunately when I'm in receiving mode and suddenly I disconnect cable it causes a hard fault for my network connection(Ethernet). How can prevent from being hang when cable has been disconnecting? How can detect this states?
    October 24, 2016
    Posted on October 24, 2016 at 21:23
    Where exactly is it Hard Faulting?
    Could you be getting a NULL pointer, and use it without checking? Could you be overrunning an array?
    Could you perhaps bounds check bitpos1?
    Can you check the PHY?
