Senior
May 4, 2024 8:36 AM UTC
Encryption csv file
Hello
MCU has SD card & USB in MSC Device mode. I am storing data on SD card in csv fatfs format. The data from SD card can be read on computer by making connecting with USB.
Now I want to encrypt the data so only my GUI application software on computer can read the csv files, otherwise anyone can open the stored csv file.
I have no experience with encyption and have tried to search  forums and see link to playlist on STM cryptography. Should i watch that ?
May 4, 2024 12:05 PM UTC
fopen, fread, fwrite, etc operate in similar ways for text and binary, it's all just "data" in 8-bit from the computer's perspective. Perhaps start with numeric representation within computers, and representation of data in memory and files?
Perhaps you can do some sort rotating Vigenere Cipher on the output of numeric values? Basically in the output routines to obfuscate the values you want to protect? A predictable pseudo-range sequence,
ie
digit = (digit + sequence(i++)) %10; // encipher
then
digit = (digit + 10 - sequence(i++)) %10; // decipher
https://en.wikipedia.org/wiki/Vigen%C3%A8re_cipher
Nico3Author
Senior
May 4, 2024 12:33 PM UTC
ok,,
I went through  rotating Vigenere Cipher and understood , so only user with known key will be able to decipher the text.
Is there any other better way ? I see some devices have encrypted .bin file. Is there any library for this ? I prefer this method if possible.
Nico3Author
Senior
May 4, 2024 1:27 PM UTC
I found sample code to convert txt to Binary then back to txt.
First I should encrypt the txt file
after that convert to Binary .. correct ?
