EMI/EMC for VBAT Backup Power Supply in STM32F407G Custom Board
I am designing a custom board based on the STM32F407G and need to provide backup power to the VBAT pin using an external battery. my board board must comply with EMI/EMC standards, what are the key requirements and design considerations when connecting the external battery to the VBAT pin?Screenshot 2024-10-25 113733.png
Andrew Neil
Andrew NeilBest answer
Have you studied Application note AN4488, Getting started with STM32F4xxxx MCU hardware development:
https://www.st.com/resource/en/application_note/an4488-getting-started-with-stm32f4xxxx-mcu-hardware-development-stmicroelectronics.pdf
It's just another digital power supply pin - so the same principles as any other digital power supply pin?
PGump.1
Senior II
October 25, 2024
EMI - make sure it does not radiate.
EMC - make sure it is not susceptible to emissions...
Given that a battery doesn't have oscillator - might be safe...
"Susceptible" - might be safe there too...
I hope that helps.
Kind regards
Pedro
AI = Artificial Intelligence, NI = No Intelligence, RI = Real Intelligence.
Andrew Neil
"EMC" = Electro-Magnetic Compatibility = both emissions and susceptibility.
PGump.1
Senior II
October 25, 2024
@Andrew Neil    they are two separate tests, conducted independently...
Kind regards
Pedro
Andrew Neil
