Dynamically change Period and Prescaler
We are using interrupt of timer function.
Currently, Period and Prescaler are set in the initial settings (MX_TIM6_Init), but what should I do if I want to dynamically change Period and Prescaler?
[IDE]STM32CubeIDE 1.14.0
[board]​ STM32F412 Discovery kit
pass3masterBest answer
Thank you for your response.
Close because your perfect answer helped me to solve the problem.
gbm
Just write new values to PSC and ARR register. Make sure that ARR preload option is turned on.
My STM32 stuff on github - compact USB device stack and more: https://github.com/gbm-ii/gbmUSBdevice
pass3masterAuthorBest answer
