hervieux
Drivers/modules uClinux on STM3210E_EVAL
  • March 15, 2010
  • 12 replies
  • 2199 views
Posted on March 15, 2010 at 11:17
    eagles8601
    May 17, 2011
    Posted on May 17, 2011 at 13:43
    Hello Cédric,
    Don't build your driver as a module, bind it to the kernel.
    Good luck
    hervieux
    hervieuxAuthor
    I managed to create a module, but the problem is that when I do the command ''insmod'' I have this error message:
    ''mymodule: unknown relocation: 10''
    ''insmod: can not insert`. / mymodule.ko `: invalid module format''
    If someone could help me, it would be nice.
    Thank you!
    Cédric
    Andrew Neil
    ''in this case where it is?''
    Your tools will put it wherever you tell them to - whether by default or a specific option setting.
    hervieux
    hervieuxAuthor
    Thank you for your reply, so I understand when recompiling the kernel I need to get a ''.o''?
    Also, in this case where it is?
    Thank you
    Cédric
    hervieux
    hervieuxAuthor
    Someone has already developed a uClinux drivers for this board?
    I feel a little lonely.
    Do not hesitate to attach source codes.
    Cédric
    hervieux
    hervieuxAuthor
    In fact, I want to use timers to my STM32F103ZE via uClinux installed above.
    And I do not understand why I could not make a module for that.
    If someone could explain ...
    Cédric
    hervieux
    hervieuxAuthor
    In fact, I have no experience in these areas ...
    I am a student intern in a company and I need to develop drivers
    for my internship.
    Understand my despair.
    Thank you for your interest.
    Andrew Neil
    I feel a little lonely.''
    Are you already experienced in embedded development in general, and/or the STM32 in particular?
    If not, it might be wise to gain some experience before diving into the arcane world of device drivers...
    hervieux
    hervieuxAuthor
    I managed to compile my module ( ''hello_world''), but when I do I try the command ''insmod'', I get the following error:
    ''mydriver: unknown relocation: 10''
    ''insmod: can not insert` `mydriver.ko: invalid module format''
    Yet, when I command ''modinf mydriver.ko'' I have the following message:
    filename: mydriver.ko
    License: GPL
    author: Cedric Hervieux, RFID
    Description: mydriver2
    Depends:
    vermagic: 2.6.26-UC0 ARMv7
    parm: major: Static Major number (none = Dynamic) (int)
    And so my ''vermagic'' corresponds with the version of my uClinux!
    Someone would have an idea?
    Thank you very much
    Cédric
    Andrew Neil
    Developing device drivers is not a task for novices - it is unfair of them to give it to you (without adequate support).
