gvuyk07
Does CubeMX take care of hardware errors? (erratas)
  • March 21, 2016
  • 626 views
Posted on March 21, 2016 at 21:27
Does CubeMx implement the workarounds described on the erratas file or that is the user's job?
    March 21, 2016
    Posted on March 22, 2016 at 00:20
    Well perhaps some of them. Usually protects you from the hazards related to the AHB/APB clock enables, and TIM->SR flag clearing etc.
    Probably less so the Cortex's tail chaining pipeline hazard.
    I'd recommend you keep the errata in mind as you code your solution. Cube is just a frame-work creator, assuming it is much else is perhaps dangerous.
    stm32cube-t
    Posted on October 07, 2016 at 12:12
    Dear user,
    it is part of our process now. Starting with STM32CubeMX 4.17 (coming out soon), STM32CubeMX shall reveal MCUs limitations as listed in the errata sheet.
    Best regards
