Feb 25, 2018 6:35 AM UTC
Documentation Issue - RM0410 Rev 3
Posted on February 25, 2018 at 07:35
The currently posted document does not address the Z-step part, see pg 1899
This document is from Nov 2017, the A and Z steps are discussed in the Oct 2016 errata, along with a reference to RM0410 for details.
http://www.st.com/resource/en/reference_manual/dm00224583.pdf
http://www.st.com/resource/en/errata_sheet/dm00257543.pdf
http://www.st.com/en/microcontrollers/stm32f769ni.html
    Tesla DeLoreanBest answer
    Feb 26, 2018 5:19 PM UTC
    Posted on February 26, 2018 at 18:19
    Also inconsistent naming of RCC_DCKCFGR1 as RCC_DCKFGR1 (pg 152 both names used in notes 2 and 3)
    pg 210 uses the wrong naming, and in a dozen or so places in doc, HAL sources refer to
    RCC_DCKCFGR1 which makes the most sense.
    Makes searching and cross-referencing with in document annoying.
    Also DCKCFGR2 used instead of RCC_DCKCFGR2 on pg 212, RCC_xx used consistently for other RCC registers and also in table of registers on pg 215-217
    Tesla DeLoreanAuthorBest answer
    Feb 27, 2018 4:22 PM UTC
    Posted on February 27, 2018 at 17:22
    Hello
    Turvey.Clive.002
    I confirm the missingaboutthe Revision Z and the wrong names that you mentioned.
    Your feedback has been reported internally to update the related reference manuals in coming release.
    Thanks andBest Regards,
    Imen
    May 16, 2018 12:19 AM UTC
    Posted on May 16, 2018 at 00:19
    Thanks, I see the new manual is posted.
