DMA Memory Increment mode overflow
Posted on March 09, 2016 at 16:37
I am using the DMA for transfer data from ADC converter to external memory RAM. The DMA is configured in incremental mode so every time that I read data from ADC converter they are stored in a different memory location. I try to be clear: -I read 16 bit of data from the data registre of ADC converter -i ask the DMA to transfer data to the RAM memory -I increment the DMA memory pointer of 2 position (each position represent a 8 bit memory register) All works fine but after writing 2^17 samples , the DMA start writing again from his original value. I haven't find anything in the datasheet about this limitation, anybody know about some sort of shadow register ? Thanks a lot for the help.DMA2_Stream0->CR&=~(7<<
25
DMA2_Stream0->CR|=(0<<
25
DMA2_Stream1->CR&=~(7<<
25
DMA2_Stream1->CR|=(2<<
25
DMA2_Stream2->CR&=~(7<<
25
DMA2_Stream2->CR|=(1<<
25
DMA2_Stream0->CR|=(1<<
13
10
DMA2_Stream1->CR|=(1<<
13
10
13
10
DMA2_Stream0->CR&=~(3<<
11
11
); //peripheral data syze imposto a half word(16bit)
DMA2_Stream1->CR&=~(3<<
11
11
DMA2_Stream2->CR&=~(3<<
11
11
6
);// imposto peripheral to memory transfer
DMA2_Stream1->CR|=(0<<
6
DMA2_Stream2->CR|=(0<<
6
DMA2_Stream0->PAR= (uint32_t)( &(ADC1->DR));
DMA2_Stream1->PAR= (uint32_t)( &(ADC3->DR));
DMA2_Stream2->PAR= (uint32_t)( &(ADC2->DR));
DMA2_Stream0->M0AR=INDIRIZZO_SDRAM_ADC1;
DMA2_Stream1->M0AR=INDIRIZZO_SDRAM_ADC3;
DMA2_Stream2->M0AR=INDIRIZZO_SDRAM_ADC2;
5
5
5
DMA2_Stream0->CR|=1; //abilito stream 0
DMA2_Stream1->CR|=1; //abilito stream 1
DMA2_Stream2->CR|=1; //abilito stream 2
#stm32f429zi-dma
