DMA circular mode and multiple adc channels
  • August 16, 2023
  • 3 replies
  • 1309 views
i am using dma circular mode for reading adc from 2 different channel. But the main problem that i faced was the value when it is in circular mode is getting offset from the value that i expect from the adc but when i used the normal mode the value was correct. Iam attaching my code below.
waclawek.jan
Which STM32?
 sConfig.SamplingTime = ADC_SAMPLETIME_2CYCLES_5;
Is the given signal's impedance low enough to support such short sampling time?
as0wanthAuthor
stm32g4 series
> sConfig.Offset = 182;
What values are you getting, and what values are you expecting? Increase sample time.
