is implementation of FAT File System in ANSI C. In STM3210E-EVAL demo program you can chose USB Mass Storage and you can copy some files to the SD card, or NAND flash. I am using .bmp files copied on NAND flash as icons in menu.
to post your icons, it is first of all necessary to manufacture icons 64x64 pixels of the types BMP 16 bits Red : 5 Green: 6 Blue: 5 then you store them in the NOR memory (by using Defus) or NAND (by using the demo mass storage) finally you post them in LCD by using the drivers. Best Regards. :))
I'm runnig the demonstration software for the STM3210E-Eval. I displayed the main menu & the icons and now I need to change these icons with some other icons according to my application to load them after thatto the Internal Flash. Can you please help me with this ?? Best Regards,
