TechMarc
Disable/enable interrupts globally on STM32F746
  • March 4, 2019
  • 5 replies
  • 1079 views
just a simple question. We share some data between ISR and application on STM32F746 processor (no RTOS used). How can we disable interrupts globally while application accesses the shared variables? Afterwards interrupts should be enabled again.
Thanks Marc
S.Ma
Principal
March 4, 2019
uint32_t SPIP_MasterRunTransaction(SPIP_t* pSPIP) {
 uint32_t tmp;
 tmp = __get_PRIMASK();
 __set_PRIMASK(tmp | 1);
 SPIP_InterruptBasedStateMachine(0);
 __set_PRIMASK(tmp);
 return 0;
Piranha
Principal III
March 6, 2019
Interrupt can still get in between lines 3-4 and change PRIMASK.
 uint32_t tmp;
 __disable_irq();
 __enable_irq();
 __set_PRIMASK(tmp);
 return 0;
turboscrew
Senior III
March 5, 2019
How about __disable_irq() and __enable_irq()?
March 6, 2019
They don't nest..
Piranha
Principal III
March 6, 2019
When accessing shared data, often it's enough to disable/enable interrupts only for particular peripheral with NVIC_DisableIRQ() and NVIC_EnableIRQ() respectively.
