Nov 20, 2024 6:34 AM UTC
diffrence between stm32f29i-disc1 and stm32f429zi
hello what is the diffrence between stm32f29i-disc1 and stm32f429zi
Andrew Neil
Andrew NeilBest answer
Nov 20, 2024 9:40 AM UTC
@mƎALLEm wrote:
Need to explain to us what do you need behind your original question: "diffrence between stm32f29i-disc1 and stm32f429zi"
@syedhashmiraza is misunderstanding / misusing the term, "microcontroller"; eg,
@syedhashmiraza wrote:
hello i am using stm32f429i-disc1 microcontroller (sic)
See: https://community.st.com/t5/stm32-mcus-products/use-stm32f4-flash-for-non-volatile-data-storage-eeprom/m-p/743291/highlight/true#M266284 - and several other places in that thread.
@syedhashmiraza The stm32f429i-disc1 is not a microcontroller - it is a board which contains, among other things, a microcontroller.
The microcontroller is the stm32f429zi
mƎALLEm
Nov 20, 2024 6:38 AM UTC
stm32f429i-disc1 is a board containing stm32f429zi microcontroller
Nov 20, 2024 6:46 AM UTC
i did not understanding what are you telling can you tell some points off thesee two boards and what are those diffrence
Andrew Neil
Nov 20, 2024 8:47 AM UTC
The difference between a chip and a board:
https://community.st.com/t5/stm32-mcus-products/communication-between-nucleo-f411re-and-raspberry-pi-using-st/m-p/721506/highlight/true#M261161
In this case, this is the STM32F429I-DISC1 board:
And this is the stm32f429zi chip (a microcontroller) - mounted on the rear of the board:
https://www.st.com/resource/en/user_manual/um1670-discovery-kit-with-stm32f429zi-mcu-stmicroelectronics.pdf#page=12
mƎALLEm
Nov 20, 2024 7:05 AM UTC
first, there is no board called stm32f29i-disc1 I supposed you are talking about stm32f429i-disc1. So please provide the correct board name.
second, as I said they are different disc1 termination means it’s a board : https://www.st.com/en/evaluation-tools/32f429idiscovery.html
while stm32f429zi is a microcontroller:
https://www.st.com/resource/en/datasheet/stm32f427vg.pdf
Hope that answers your question
Nov 20, 2024 9:03 AM UTC
you mean these two boards are same
mƎALLEm
Nov 20, 2024 9:04 AM UTC
What words you are talking about?
