Tobe
Senior III
Jan 28, 2025 8:53 AM UTC
Did i just brick my G431 with a failed FLASH option byte write?
i tried to write a option byte, which did not work i think.
A FLASH mass erase with the programmer does not work: "Error: Mass erase operation failed.Please verify flash protection"
Is it possible to brick a chip with a failed flash write operation?
while(READ_BIT(FLASH->SR, FLASH_SR_BSY));	// Wait to until no flash activity
if(HAL_FLASH_Unlock();		// Unlock FLASH
HAL_FLASH_OB_Unlock();	// Unlock Option bytes
WRITE_REG(FLASH->OPTR, 0xfbeff8aa);
SET_BIT(FLASH->CR, FLASH_CR_OPTSTRT);
Tobe
TobeBest answer
Senior III
Jan 28, 2025 9:56 AM UTC
Just found the cause:
Readout protection was set to "FF". Since i did not set it, i did not consider it. Everyday you learn something new....
Setting it to "AA" solved the issue.
Tobe
TobeAuthorBest answer
Senior III
