Detecting available UARTs at compile time
using CubeIDE with CubeMX, is is possible to "check" or "detect", for conditional compiling, which UART ports that are enabled? In the MX-generated USART.C you will find all the handles for the available UARTs but AFAIK, you can't conditional compile on the existence of variables, only #defines. Then, in the stm32h750xx.h (H750 in my case) you can find #defines for the UART ports but that is ALL the MCU's ports, not only used ones.
Regards,
Goran
