Mohammad A
Senior
Jun 23, 2019 1:34 PM UTC
Defining NOLOAD section in ld script for GCC
I want to define a new section in ld script so I can use that for variables which have to keep their values in case of soft resets (like IWDG).
I have done some researches and wrote something like this and added that below the .bss section in ld file.
/* Uninitialized data section into "RAM" Ram type memory */
 . = ALIGN(4);
 .bss :
 /* This is used by the startup in order to initialize the .bss secion */
 _sbss = .; /* define a global symbol at bss start */
 __bss_start__ = _sbss;
 *(.bss)
 *(.bss*)
 *(COMMON)
 . = ALIGN(4);
 _ebss = .; /* define a global symbol at bss end */
 __bss_end__ = _ebss;
 } >RAM
	 * .noinit section - uninitialized data
	.noinit (NOLOAD):
		. = ALIGN(4);
		_start_of_noinit = .;
		*(.noinit)
		*(.noinit.*)
		. = ALIGN(4);
		_end_of_noinit = .;
 } >RAM
 /* User_heap_stack section, used to check that there is enough "RAM" Ram type memory left */
 ._user_heap_stack :
 . = ALIGN(8);
 PROVIDE ( end = . );
 PROVIDE ( _end = . );
 . = . + _Min_Heap_Size;
 . = . + _Min_Stack_Size;
 . = ALIGN(8);
 } >RAM
I also define this kind of variables in this way:
uint32_t aVeryStableGeniusVariableArray[10] __attribute__ ((section (".noinit")));
As I'm not an expert in ld technics, I just wanted to know if the above code is OK and does not cause any unwanted malfunction.
Actual ld file is attached.
    Jun 23, 2019 3:19 PM UTC
    The .MAP file would allow you to confirm the placement by the linker. The secondary dependency would come from startup.s
