antonius
#define __HAL_SD_SDIO_ENABLE_IT ?
Posted on March 08, 2017 at 15:13
Everybody,
How can I disable :
without STM32CubeMX ?
    Posted on March 08, 2017 at 15:24
    To disable the SD device interrupt you should use: __HAL_SD_SDIO_DISABLE_IT
    You can refer to your cube firmware package to see their stm32xxxx_hal_sd.h/.c structure and get inspired from them.
    You may refer to the working SD examples within your STM32cube, this will help you on your implementation.
    Imen
