Debugging the MCU on a NUCLEO-H7A3ZI if 1.8V is selected?
Dear all,
It seems like I actually broke two Nucleo 144 with a H7A3 and H723 after I tried to debug the MCU with the on board debugger and after switching the supply voltage for the MCU to 1.8V (no connection from debugger to MCU possible, even not with 3.3V again).
Is this problem known? If yes, I am wondering, why there is actually the possibility to switch to 1.8V. I found several blog entries that this is not allowed since no level shifters are on the board, but I couldn't find it in the user manuals of the mentioned boards. Did I miss anything?
I really would appreciate your help!
Thank you a lot in advance.
Best regards
