debugger, what is it really doing
Posted on April 03, 2016 at 23:20
Hi everyone,
I wonder exactly what the debugger is doing when I attach it with gdb. What is the big difference between running with debugger and without debugger?Does it use its own startup code ?Does it do stuff with clock registers ?Different entry point ?Etc...I have st-link v2 debugger and the reason for asking is that my sdram stops working when outside debugger (attach it once in gdb and just quit gdb makes the board restart and then makes the sdram work as well).Regards,Troy1818
