Jul 26, 2024 6:52 AM UTC
Debug Set to No Debug
Hi i want to know how can i fix the MCU's when i accidentally set the Debug mode to No debug in ioc file as i can not connect it now
Andrew Neil
Jul 26, 2024 9:53 AM UTC
Use "connect under reset"
AScha.3
Jul 26, 2024 10:02 AM UTC
set reset : hardware (if you do anything with these pins in your program: only debug under hardware reset , to load /flash the program.)
If you want "normal" debug, set it in Cube/ioc , gen.code , then you have it (again).
