Brother Theo
Debug not stating correctly
  • October 24, 2018
  • 631 views
When I start a debug session, the program start immediately instead of pausing, and the cursor is not at main() but at an odd spot in assembly. Using system workbench and a nucleo as a programmer. this is a custom target board running an STM32f091. What can cause this?
    October 24, 2018
    Code has not be downloaded properly. Break-points not set properly.
    Try using pro-tools like Keil, should be a free license for STM32 CM0 parts.
    Brother Theo
    So after much messing it is now mostly starting okay but I zm not getting timer interrupts. They work in run mode but not in debug. i checked the timer and it seems to be counting. wierd.
