DC Relay Heat when it's closed bypass suggestions
Hello everyone,
I'm working on a projects that countains a stm32l152re to communicate with temperature/Humidity sensor amongst other sensors and a DC relay to control some light bulps. However, when the relay is closed, it overheat and corrupt the measured data from the sensors. I know this problem can be looked at from different perspectives (electronics, Mechanics and firmware).
I'm a junior embedded system developer. I contributed to this project by developing firmware for some of the sensors and I've been asked recently to give a suggestion for the heating problem. I searched on the net but couldn't find some valuable info that I could use. Any suggestions will be very welcome especially a firmware one.
I'm open into any questions or more detailed informations. Thanks !
