spa23
DAC offset problem
  • October 18, 2013
  • 613 views
Posted on October 18, 2013 at 09:50
HI
I have a small issue with the DAC in a stm32F103, there Is a small offset between DAC_DHR12R1 and DAC_DOR1 registers
The code is pretty simple:
DAC_InitStructure.DAC_Trigger = DAC_Trigger_Software;
DAC_InitStructure.DAC_WaveGeneration = DAC_WaveGeneration_None;
DAC_InitStructure.DAC_OutputBuffer = DAC_OutputBuffer_Enable;
DAC_Init( DAC_Channel_1, &DAC_InitStructure );
DAC_SetChannel1Data( DAC_Align_12b_R, value );
DAC_SoftwareTriggerCmd(DAC_Channel_1, ENABLE);
And the test result:
DAC_DHR12R1 DAC_DOR1
40 41
409 411
1023 1026
2047 2051
3071 3076
4095 5
Has anyone else seen the same problem?
Another thing is that I can�t get it to work with DAC_Trigger_None. any ideas?
#dac
Amel NASRI
Technical Moderator
October 22, 2013
Posted on October 22, 2013 at 11:40
Hi Panduro,
Isn't the commande enabling the DAC Channel1 missed?
DAC_Cmd(DAC_Channel_1, ENABLE);
-Mayla-
spa23
spa23Author
Posted on October 23, 2013 at 09:42
Yes, (copy paste error) I have it in my code.
