mpare.285
Aug 8, 2018 3:26 PM UTC
CubeMx and ST32F765BI : LSE issue
Hi all,
I have a problem with STM32F765BI and LSE configuration in CubeMx : when I enable LSE in the PINOUT Panel, an erroror comes out in the clock panel and I cant set properly a value for the clock. The red box is not editable.
How can I solve?
Thanks,
Matteo
    Aug 8, 2018 3:59 PM UTC
    Which version of CubeMx are you using?
    Can you please share your ioc file for check your case.
    With Regards,
    Imen
    mpare.285
    mpare.285Author
    Aug 8, 2018 4:24 PM UTC
    the version of CubeMx is 4.26.1
    Attached the .ioc file
    Thanks,
    Matteo
    Houda GHABRI
    Aug 15, 2018 9:27 AM UTC
    Hello @mpare.285​ ,
    Thanks for your feedback.
    To avoid this issue you can:
    - switch LSE clock to "Bypass Clock source"
    - modify LSE vlaue to 32.768 KHz as fixed in DS
    -In Pinout Panel change LSE source to "Crystal/Ceramic Resonator".
    please feel free to contact me for furthers details.
    Regards,
    Houda
    mpare.285
    mpare.285Author
    Aug 27, 2018 12:06 PM UTC
    I have tried without fortune.
    This is what I do:
    1- set LSE clock to "Bypass Clock Source" in pinout panel [OK]
    2- modify LSE value in clock configuration panel [OK]
    3 - change LSE clock source to "Crystal...". When I do this I get the error on page clock configuration panel
    Do you have any other suggestion?
    Thanks.
    Matteo
