CubeMX and CubeIDE interaction - User Code being overwritten
when I change configuraion of my procejt STM32F103 in CubeMX  e.g.
PIN&Configuration / SYS / Debug    item is changed  from "4 pins" to "5 pins" and I push "GENERATE buton" the code inside While cycle in main.c function in CubeIDE is changed at the same time. It is terrible. I thought that If I insert my user code inside the /* USER CODE END WHILE */  clause all such code is protected against changing when configuraion of my project is done in CubeMX. But it is NOT true. How can I solve this problem ?
 /* Infinite loop */
 /* USER CODE BEGIN WHILE */
 while (1)
	 // LED ON
	 HAL_GPIO_WritePin(GPIOB, GPIO_PIN_14, GPIO_PIN_SET);
	 HAL_GPIO_WritePin(GPIOB, GPIO_PIN_15, GPIO_PIN_RESET);
	 HAL_Delay(500);
	 // LED OFF
	 HAL_GPIO_WritePin(GPIOB, GPIO_PIN_14, GPIO_PIN_RESET);
	 HAL_GPIO_WritePin(GPIOB, GPIO_PIN_15, GPIO_PIN_SET);
	 HAL_Delay(500);
 /* USER CODE BEGIN 3 */
 /* USER CODE END 3 */
Andrew Neil
Andrew NeilBest answer
You need to put your code between the USER CODE BEGIN xxx marker and the USER CODE END xxx marker;
In other words, your code must come after the USER CODE BEGIN xxx marker and before the USER CODE END xxx marker.
What you posted has your code after the USER CODE END xxx marker - so it is outside the protection of the User Block:
 /* Infinite loop */
 /* USER CODE BEGIN WHILE */ <=== User Block STARTS here
 while (1)
 /* USER CODE END WHILE */ <=== User Block ENDS here
	 // This code is OUTSIDE the User Blocks!!
	 // LED ON
	 HAL_Delay(500);
	 // LED OFF
	 HAL_Delay(500);
 /* USER CODE BEGIN 3 */ <=== User Block STARTS here
 /* USER CODE END 3 */ <=== User Block ENDS here
PS:
This was already explained by @SOgal.1 in your previous thread:
https://community.st.com/t5/stm32-mcus-boards-and-hardware/code-debugging-using-stlinkv2/m-p/767142/highlight/true#M23748
and by me - with link to previous examples:
https://community.st.com/t5/stm32-mcus-boards-and-hardware/code-debugging-using-stlinkv2/m-p/767156/highlight/true#M23752
PPS:
If you find the positioning of those markers odd, see:
https://community.st.com/t5/stm32cubemx-mcus/stm32cubeide-while-1-bug-linux-versions/m-p/751755
Andrew Neil
 /* Infinite loop */
 while (1)
	 // LED ON
	 HAL_Delay(500);
	 // LED OFF
	 HAL_Delay(500);
PS:
PPS:
JerryMC22Author
wou thanks it is working. :)
