CubeMX 4.25.0 bug report
Hello!
I have just updated CubeMX to 4.25.0 but none of the generated codes work within Keil. If i use code from older projects which were made by CubeMX 4.24 ,they work flawlessly but if i generate a simple initialization code with CubeMX and try even blink a LED on STM32L476 Discovery board it does not work.
Did anyone notice some troubles with the update?
int main(void)
{ /* USER CODE BEGIN 1 *//* USER CODE END 1 */
/* MCU Configuration----------------------------------------------------------*/
HAL_Init();/* USER CODE BEGIN Init */
/* USER CODE END Init */
SystemClock_Config();/* USER CODE BEGIN SysInit */
/* USER CODE END SysInit */
MX_GPIO_Init(); MX_I2C1_Init(); MX_I2C2_Init(); MX_LCD_Init(); MX_QUADSPI_Init(); MX_SAI1_Init(); MX_SPI2_Init(); MX_USART2_UART_Init(); MX_USB_HOST_Init(); /* USER CODE BEGIN 2 *//* USER CODE END 2 */
/* Infinite loop */
/* USER CODE BEGIN WHILE */ while (1) { HAL_Delay(300); HAL_GPIO_TogglePin(GPIOB, GPIO_PIN_2);/* USER CODE BEGIN 3 */
/* USER CODE END 3 */}
