Cube Clock Confgration bug
Posted on May 19, 2016 at 09:00
Dear all ST staffs,
I found a bug about clock configuration for F429-NUCLEO in cubeMX. I want you to fix this problem.
To reproduce the bug, please make a new F429-NUCLEO project, and choose HSI as clock source. The frequency value of HSI at CubeMX is 8 MHz, but datasheet says it is 16 MHz.I hope my contribution will help you.
Best regards, Fumihiko.
