Adalgiso
cube 4.21 hangs generating code
  • May 11, 2017
  • 5 replies
  • 1578 views
Posted on May 11, 2017 at 14:51
I did upgrade to cube 4.21 and for 1 project, when generating the source code, cube MX hangs.
I have to specify that it hangs only for 1 of my project.
    Nesrine M_O
    Posted on May 11, 2017 at 15:41
    Hi
    Castrignano.Adalgiso
    • Could you please precisetheSTM32 product with it you have found the issue?
    • Couldyou please share the log files placed inyour user directory under the .stm32cubemx folder.
    -Nesrine-
    Nesrine M_O
    Posted on May 11, 2017 at 16:03
    Hi
    Hi, Can you specify how to share a file, I searched on the forum but could not find a way to attach a file?
    -Nesrine-
    Adalgiso
    AdalgisoAuthor
    Denny Smith
    Posted on May 14, 2017 at 03:16
    Probably too obvious an answer but I have found that CubeMX will hang when generating project if uVision is already open on that project.  The only way to move on is to terminate CubeMX with Windows Task Manager.
    Adalgiso
    AdalgisoAuthor
    Posted on May 15, 2017 at 11:05
    I am using IAR compiler, and with IAR open or closed I have the same issue and this only on 1 of my project. It works fine for other project. I attached my log file hopefully I will get some feedback from ST team.
    Nesrine M_O
    Posted on May 15, 2017 at 11:26
    Hi
    This issue has been reported internally to our MX team for for checking,Sorry for the inconvenience it may bring.
    -Nesrine-
    Adalgiso
    AdalgisoAuthor
    Posted on July 06, 2017 at 08:36
    Hi
    Any news on this issue, has something been found and if yes by when can we expect a fix or solution?
    Ricardo Hassan
    Posted on June 07, 2017 at 01:31
    I see a similar behavior. CubeMX 4.21, building for IAR toolchain, STM32CubeL4 1.8.0. My target is an STM32L486
    ________________
    Attachments :
    STM32CubeMX.log.zip : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006HycZ&d=%2Fa%2F0X0000000bAC%2FmB8YouABJ_eScl7sCfnjSe7KzgekKiwPqxldHaiUxg4&asPdf=false
