drechsel
Sep 5, 2009 12:24 PM UTC
CRC calculation in software
Posted on September 05, 2009 at 14:24
    Shang.Dawei
    May 17, 2011 11:17 AM UTC
    Posted on May 17, 2011 at 13:17
    [DEAD LINK /public/STe2ecommunities/mcu/Lists/ARM%20CortexM3%20STM32/Flat.aspx?RootFolder=/public/STe2ecommunities/mcu/Lists/ARM CortexM3 STM32/CRC32 calculation mismatch&FolderCTID=0x01200200770978C69A1141439FE559EB459D758000626BE2B829C32145B9EB5739142DC17E&currentviews=635]https://my.st.com/public/STe2ecommunities/mcu/Lists/ARM%20CortexM3%20STM32/Flat.aspx?RootFolder=/public/STe2ecommunities/mcu/Lists/ARM%20CortexM3%20STM32/CRC32%20calculation%20mismatch&FolderCTID=0x01200200770978C69A1141439FE559EB459D758000626BE2B829C32145B9EB5739142DC17E&currentviews=635
    DWORD CRC32WideFast(DWORD Crc, DWORD Size, BYTE *Buffer)
    Size = Size >> 2; // /4
    while(Size--)
    static const DWORD CrcTable[16] = { // Nibble lookup table for 0x04C11DB7 polynomial
    0x00000000,0x04C11DB7,0x09823B6E,0x0D4326D9,0x130476DC,0x17C56B6B,0x1A864DB2,0x1E475005,
    0x2608EDB8,0x22C9F00F,0x2F8AD6D6,0x2B4BCB61,0x350C9B64,0x31CD86D3,0x3C8EA00A,0x384FBDBD };
    Crc = Crc ^ *((DWORD *)Buffer); // Apply all 32-bits
    Buffer += 4;
    // Process 32-bits, 4 at a time, or 8 rounds
    Crc = (Crc << 4) ^ CrcTable[Crc >> 28]; // Assumes 32-bit reg, masking index to 4-bits
    Crc = (Crc << 4) ^ CrcTable[Crc >> 28]; //  0x04C11DB7 Polynomial used in STM32
    return(Crc);
    petter23
    Oct 11, 2011 12:53 PM UTC
    Posted on October 11, 2011 at 14:53
    I got this code to produce what seems to be CRC-32 on even 4-byte input using the CRC unit correctly, at least it produces the same CRC-32 as perl crc32 and some other CRC-32 according to the mentioned specifikation earler.
    #include ''stm32f2xx.h''
    uint32_t my_crc32(uint8_t* data, uint32_t len)
        uint32_t* pBuffer = (uint32_t*) data;
        uint32_t BufferLength = len/4;
        uint32_t index = 0;
        RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_CRC, ENABLE);
        CRC_ResetDR();
        for(index = 0; index < BufferLength; index++)
            CRC->DR = __RBIT(pBuffer[index]);
        return __RBIT(CRC->DR) ^ 0xFFFFFFFF;
    Oct 11, 2011 1:37 PM UTC
    Posted on October 11, 2011 at 15:37
    There have been quite a few discussions on CRC computation, including this one which adapts mcuisp's 32-bit algorithm to byte boundary conditions.
    [DEAD LINK /public/STe2ecommunities/mcu/Lists/cortex_mx_stm32/Flat.aspx?RootFolder=/public/STe2ecommunities/mcu/Lists/cortex_mx_stm32/CRC computation&FolderCTID=0x01200200770978C69A1141439FE559EB459D7580009C4E14902C3CDE46A77F0FFD06506F5B&currentviews=1034]CRC Computation
    Unfortunately most of the pre May-2011 links are broken due to forum software failures.
    Feb 3, 2018 5:03 PM UTC
    Posted on February 03, 2018 at 17:03
    Current working link
    https://community.st.com/0D50X00009XkbNMSAZ
    rdittmar
    Mar 29, 2012 2:45 PM UTC
    Posted on March 29, 2012 at 16:45
    Hey swhite!
    Perfect - thank you - that helped me a lot!!!
