juliensineau9
crash system with EEPROM emulation in STM32F0xx microcontrollers
  • April 19, 2013
  • 6 replies
  • 1272 views
Posted on April 19, 2013 at 11:04
For my tests, i use a STM32F0 discovery and i download on the ST website, the
software.
http://www.st.com/web/en/catalog/tools/PF258153
When i run this demo project with �Vision 4, the execution of this sofware causes a crash of my debug session.
I remark that the crash
happens when
the loop
is used to write
the data
is
larger than the
page size
. But when i execute the same software in step by step, no crash happens !
I suppose that a timing problem.
Can you help me ?
#stm32f0-eeprom-emulation-bug #forum-says-no
juliensineau9
Posted on April 25, 2013 at 11:37
up
April 25, 2013
Posted on April 25, 2013 at 11:51
Crashes how exactly, and on what instruction? You provide no code/process to demonstrate the failure. Does it fail every time? The first time? When you run it a dozen times, or modify it?
Before kicking posts, consider why they are being ignored.
juliensineau9
Posted on April 25, 2013 at 16:02
I found alone !!!
FLASH_SetLatency(); !!!
Steps for reproduce this bug:
- Buy the F0 Discovery board
- Download the exemple
- Load
- Run
- Crash !!!
It
is clear
this time?
emalund
Posted on April 25, 2013 at 17:14
sure, I'll run out and spend some money to help you for free
Crashes how exactly, and on what instruction? You still provide no code/process to demonstrate the failure. Does it fail every time? The first time?
anyhow, I have a good guess.  you forget that flash is page based and using some ''EEPROM bytes'' in a page that contains code, of course, makes that page erase.
Erik
April 25, 2013
Posted on April 25, 2013 at 18:14
It
is clear
this time?
Not much frankly, does it output a message saying ''Crash!!!'', or can you figure out where it is by stopping the CPU in the debugger? Does it get stuck in a loop, the Hard Fault handler?
Other useful information might be what tool chain you're using?
kevinliao
Posted on September 04, 2015 at 09:25
Hi, ST sirs,
I also have the write data eeprom will ''crash'' problem,
I found that when the value of data = 0x00, the system will crash.
Is that need spacial process when data value = 0x00.
By the way, why the data eeprom need erase process?
When will the data eeprom need be erase?
I just do the read and write procedure.
Thank you.
Kevin
