joneuhaus
Mar 18, 2008 4:58 AM UTC
Count the frequency of 3 external signals
Posted on March 18, 2008 at 05:58
    joneuhaus
    joneuhausAuthor
    May 17, 2011 10:26 AM UTC
    Posted on May 17, 2011 at 12:26
    I would like to measure the frequency of 3 differents signal (max frequency = 100kHz).
    What is the best way to handle this problem?
    > Use the Timers 2,3 and 4 in Input Capture mode and check the value of the counter register each second
    > Use an interruption to detect new pulse
    > Use an external counter and retrieve its value each second (which one?)
    > others ideas?
    Have you some configuration example to use a Timer in Input Capture mode?
    Thank you in advance for your advices.
    joneuhaus
    joneuhausAuthor
    I have used an other way to measure frequency : I use a standard input and retrieve the value each second. Here is the code.
    It works up to 450kHz, on 3 different inputs.
    Here is the main code :
    int main (void)
    /* System Clocks Configuration */
    RCC_Configuration();
    /* NVIC configuration */
    NVIC_Configuration();
    /* Configure the GPIOs */
    GPIO_Configuration();
    /* Configure the USART1 */
    USART_Configuration();
    /* Clear reset flags */
    RCC_ClearFlag();
    /* private variables declaration */
    bool bln_HF1,bln_F1,bln_E1;
    bool bln_HF2,bln_F2,bln_E2;
    bool bln_HF3,bln_F3,bln_E3;
    unsigned int value=0;
    int cpt1=0,cpt2=0;
    /* Infinite loop */
    while (1)
    /* If 1s has passed */
    if(TimeDisplay == 1)
    /* Display counter values */
    printf(''cpt1 : %d / cpt2 : %d/ cpt2 : %d\t'',cpt1,cpt2,cpt3);
    cpt1=0;
    /* Rising edge detection and incrementation of counter 1 (PC1) */
    bln_E1=GPIO_ReadInputDataBit(GPIOC, GPIO_Pin_1);
    bln_F1=~bln_HF1&bln_E1;
    bln_HF1=bln_E1;
    if (bln_F1) cpt1++;
    /* Rising edge detection and incrementation of counter 2 (PB9) */
    bln_E2=GPIO_ReadInputDataBit(GPIOB, GPIO_Pin_9);
    bln_F2=~bln_HF2&bln_E2;
    bln_HF2=bln_E2;
    if (bln_F2) cpt2++;
    /* Rising edge detection and incrementation of counter 2 (PA0) */
    bln_E3=GPIO_ReadInputDataBit(GPIOA, GPIO_Pin_0);
    bln_F3=~bln_HF3&bln_E3;
    bln_HF3=bln_E3;
    if (bln_F3) cpt3++;
