charles2399
cortexm3_macro problems - can not compile
  • October 31, 2008
  • 3 replies
  • 758 views
Posted on October 31, 2008 at 15:53
    charles2399
    Posted on May 17, 2011 at 12:50
    We have an STM3210E-EVAL board and we are using the Green Hills tool set.
    None of the supplied CorTexM3_macro.asm targets the Green Hills tool set.
    When I modify one to match the syntax of our assembler we get a number of errors. Instruction WFI, SEV and isb are flagged as unknown instructions. Other lines of assembly code are flagged as instruction unsupported in this context, e.g. MRS r4, CONTROL.
    I do not see where CONTROL is defined.
    Any suggestion to cure these problems.
    charles2399
    they do support, but the assembly language file is provided by ST with their examples for the evaluation board.
    st3
    Considering the price tag of Green Hills, don't they provide support? :o
