The value in LR at the Hard Fault handler is a magic value which imparts information to the processor about how to return the the prior system/user state. It will not be the faulting instruction.
Implement a REAL Hard Fault Handler to decode the system state and faulting PC. Joseph Yiu has posted several real good examples of this, and his books on the Cortex-M3 is recommended.
If you refer to the materials cited, you could interpret it yourself. To do it properly you need to interact with the debugger to review the faulting code, and the register context with respect to that code and what it was doing. Go look at the Thumb2 code you have at around 0x080066CF (the instruction immediately before) You can't review the core's register from a BMP
